Drock
- 9
- 0
- Eatonton GA
I finally finished the install of my sidewinder turbo. And according to the directions, at 60MPH the EGT should be 400 degrees with 1 to 1-1/2 LBS of boost. But mine is running 500-600 degrees and no boost. I was thinking this may be because our CUCV's perhaps run lower gears then the civilian K30's, thus more RPM's may = more EGT??? Or am I just running too much fuel advance , and should back it off ah little?? What temps are you guy's getting?
