- 8,218
- 20,766
- 113
- Charlotte NC
.Update:
I want to thank everyone for your comments up this point.
Yesterday I was removing some of the terminals from the LBCD, starting with the top one. I put it all back together and, as you know, nothings would start.
Today, I was able to pull the LBCD, which was a total pain to explore it more. While doing so (with the power on), I was removing the top terminal and I could hear the all the buzzers in the interior turn on!
From the prior day, I inadvertently sheared the stud on the 24V Batt terminal. This was an oversight on my part - I think this is a special stud. Notice the threads taper to a smaller diameter?
The other issue is that the nut that was epoxied into LBCD was loose and can be removed.
Here is a picture of the little bit of the stud still inside the LBCD.
So, I need some recommendations.
1. Do I attempt a repair or do I need to replace?
2. If repair, how to secure the nut into the LBCD? Epoxy, some other adhesive?
3. Do I attempt to remove the bit of stud?
4. If yes, any ideas on where I can buy a replacement?
5. If no, do you suggest a conductive paste or another solution?
6. Did I forget to ask anything?
Thanks in advance guys. You have been very helpful!
By the way, I checked all the battery voltages today. All stable at 12.4V- 12.8V
Well, I guess the happy part is that you found your problem. My opinion is that there isn't any way to reliably repair it. You already know what a PITA is was to take it out. Putting it back won't be any easier. The third time when you are on the side of the road when the epoxy shakes itself loose (and it is raining and cold) will be a Royal PITA.
It is possible that you can find one here on the Parts Wanted (Classifieds) Section. @wheelspinner or @TacMac2012 occasionally have M107x or M108x trucks that are scrapped for parts. They could be a good source for a replacement...
