Bead Breaker
Blood_of_Tyrants
11
Lebanon, TN
All those hours I spent in the motor pool, sweating over tire changing using noting more than a sledge hammer and angle iron "wedges" because the mechanics said that was the "Army way"? And they had these hidden somewhere in the back of the tool trailer?
Where would I apply for compensation for such torture?:roll:
With all the women in the Army now, I'll bet that they have gotten these hydro-pneumatic jobs so the women can"do the same things a man can do".:roll:
DavidB
58
Southeast Wi.
Latest word at the NG armory is wheels and tires come and go as set.must need to use up some NOS stuff. I use the small pneumatic/hydraulic bead breaker. It works great and will do ag tractor tires mounted on machine.As others posted airing is where you can run into problems,be safe.
DavidB
11Echo
96
CT W. R.
I think this is the tool you are refering to. It is in TM 9-1870-1 "Pneumatic Tires" Feb 1955
I have only seen a few of them and they seem complex. But the illustrations may give you a few ideas. The better machine is the Bishman tire changer As used by the US ARMY. I have one and they work great. They turn up on GL everyonce in a while. Much better tool. Just taking your tires to the local truck tire shop is the easiest thing to do. And usually worth the money if you are only changing a few.
Cat Man
Do you have any pics of a Bishman in action?
1,164
I have a bunch of wheels I need to break down this winter to have blasted so I can paint them and mount some new tires. Last few I broke down, I used the spade on my tire machine at work, but the batch of rims I am working on are ancient and the spade just can't quite get the tire far enough down (it's on a passenger car mounting machine).
So I think I am going to go ahead and buy a bead breaker.... you guy see any problem with something like this:
Portable Bead Breaker : Fits All Rim Types Heavy Duty :eBay Motors (item 400084565618 end time Nov-17-09 08:08:09 PST)
Stretch44875
Super Jr. Moderator
33
Tiro, Ohio
I would say that one will work. Just need a high pressure pump to operate it. It should be rated for 10,000 psi. You can hand pump them, just will take a while.
CARNAC
The Envelope Please.
724
College Station, TX
If anyone can help me out, I'm looking for a picture of this specific item and cannot find it on the web.
4910-01-325-2974
BEAD BREAKER,PNEUMA, MANUALLY OPERATED,WORKS 1300 X 24, 1400 X 24, AND 15.5 X 25 WHEELS AND DROP WHEELS, 750 X 15 TO 17.5 X 25,
Civy model is a Galaxy BB105289 or Brannick MBB
Need a good photo. Thanks
Ferroequinologist
Resident railroad expert
4,813
750
Liberty Hill, SC
My wife broke down and changed most of the 9x20s to 11r20s on her M109 using the 3 pieces of angle iron and a sledge. I broke down a few too. Still could only do 2 each a day.
I have just recently started looking for a breaker. Figures, after I've already changed 20 the hard way...
Dave Kay
31
Kingman AZ
I need some advice on this subject; Talking about regular tire/rims, NOT split rims.
Got some tire irons and been taking tires off wheels with NO problems lately, using a few differnt methods for breaking beads of course, and I can get tires off the rims alright but in doing so I'm getting some damage to the tire's bead-area. Like tears and gouges. Now these are all old, worn tires so that damage doesn't matter.
But I want to know is if I'm going to de-mount tires and re-mount tires back onto rims what am I doing wrong that's tearing up the tire's bead? Wrong tool? Wrong technique? Or maybe just old, worn out tire rubber? Any comments would be appreciated.
Here's what I've got;
Kohburn
SOMD
those tires look too dry rotted to remount to me - even if they hadn't been damaged by the spoons.
Dave Kay
31
Kingman AZ
Roger that, not looking to re-mount those oldies. But I am looking to maybe buy some new tires (or newer used) and mount to rims then go get 'em balanced. My idea is to save a few bucks on mounting because winter treads are what I need for now. Then later when when summer rolls around I'll want to change back to a differnt tread, ect,.
