- 34,012
- 1,810
- 113
- GA Mountains
Jesusgatos,what's in the way? BTW, as soon as my fun acct gets replenished, I'm getting a pair of the steps you make for the back of the wrecker.
Here's a picture to show you what I'm talking about. I can't remove that fitting without taking off the back cover of the transfer-case. I guess I could cut/grind off the 90, then install a straight 1/4" NPT fitting and then stack a 90 on top of that. That would probably give me enough clearance, but I'd rather just use the fitting that's already in there. I tried fitting a standard compression olive in there, and it's close, but it bottoms out against the flat part inside just before the angled part of the olive makes contact with the angled part of the fitting. I think it might crush enough to work OK, but I don't want to cut any corners. What do you guy think I should do about this? I'm going to remove the parking brake drum anyway (to change the rear output seal), but I'd rather not have to take off that back part of the case. Is it something that I could just R & R easily?Jesusgatos,what's in the way? BTW, as soon as my fun acct gets replenished, I'm getting a pair of the steps you make for the back of the wrecker.
Thanks. I tried (half-heartedly) to do that right off the bat, but after you suggested it, I went back and gave it another try. Managed to get it off without damaging it, and was able to get my new oil-line installed.What we used to do sometimes, when we didn't have another ferrule, was to put the ferrule back into the nut and then set the nut on top of a vise with the jaws opened far enough to let the tube extend down into the jaws. Since that tube looks like 1/4" take a 1/4" drift punch and drive the tube through the ferrule with it. This will open the ferrule up at the same time to the tube size. We used to do this on ships when we didn't have any more ferrules in inventory and were days away from port and a store to get some.
Since you have the seal bent out that far either try grabbing it with a pair of vice grips and smack the vice grips with a hammer or take a chisel and see if you can collapse the seal housing.
OK. Had to call it a night on account of the rain, but I'll give the seals another go tomorrow. Don't think vise-grips are going to do it, and I'm a little bit reluctant to use a torch so close to the bearings (wasn't planning on replacing them unless they look bad), but I'm about out of alternatives. I've got several different bearing pullers, but all of the jaws are too wide to get in between the seal lips and the input/output shafts.and a bit of heat some repare ppl seem to like to put red locktight everywhere 400degreesdoes it usually
Sorry, I missed this. You know, you're only the 3rd or 4th person that's expressed any interest. I made three sets for my truck, and one set for Clinton at C & C, but that's it.BTW, as soon as my fun acct gets replenished, I'm getting a pair of the steps you make for the back of the wrecker.
...and I obviously missed this.I replaced the seals in my xfer case last year. I had to remove the retainers and use a drift and a large hammer to pound them out.
