Best Gear shift knob
drdstny
Banned
187
Portsmouth, NH
I'm sitting here staring at a cyclic stick for an N model huey, I've installed them in several vehicles including a 39 chevy coupe.
Traded this stick to devilman for a set of airhorns, it was out of an F86
THAT'S ABSOLUTELY BAD-ASSIN!
Got more? :)
So when you say "cyclic," could that also mean "collective?" That might work too.
I like mods like this. It's like The Original Green Pride.
AN/ARC186
Graham,Washington
Got more? :)
Yep, still have a couple, not sure if I'll have extra's yet, you'll be the first I let know.
Well, the collective in an H-1 usually has flight idle, engine start, throttle, searchlight functions etc. it's pretty boxey compared to the cyclic.
might be a bit cumbersome for a shift knob.
AN/ARC186
Graham,Washington
Here are some pics of the 39 install, making an adapter for the shifter in the deuce, will post pics when I find my **** camera (I just love moving)
first two are of the stick location, third is the fuse panel and relay center that connect the stick to various car functions, in this case stereo vol, radio tune, cd track, hi/lo beams, turn sig, door releases, trunk release, horn.
drdstny
Banned
187
Portsmouth, NH
My friend, that is a Whole Lot of Kick Ass(tm).
Terrific way to combine disciplines. I like it a lot!
So what do the switches do? Line lock, N2O, Afterburners and TailLight Blackout? :)
In my case, the pot/joystick would be good for either a rv-camera or centering the steering. I can come up with uses! :)
AN/ARC186
Graham,Washington
The coolie hat is stereo vol, radio tune and turn signals, trigger is horn, switch at bottom is starter, center switch is door and trunk releases, switch next to coolie hat is hi/lo beam
AN/ARC186
Graham,Washington
Finally got around to installing the new shifter knob. Had to bend the shift lever a bit to make it sit just right. Now just have to connect it up. I went with an old grip from a GAU-17 mount for the UH-1N. Its made of the same materiel as the old shift knob. Replaced the indicator light with a thumb switch so I would have a two switches, the trigger and the thumb.
OPCOM
29
Dallas, Texas
I've got plans for one of these at least. They are cast resin of some kind. I was handed a bag with them in it as a gag. Not what I always wanted, but with some grinding to remove the excess at the base, ought to make a nice shift knob. These are decent size about 3.5" tall. I figure 0.5" uranium glass marbles for the eyes and a little paint.
Billy Bobbed
13
Terre Haute,Indiana
Well heres my cheap plastic shift knob I put on yesterday:oops:.I cant aford the real thing,I took this off a F-16 flight stick for a computer.I shot alot of cars on the way home today.Let me tell you it works and fits very well.I'll use it for awhile untill I find one better.
jamesfrom180
73
Gainesville/Florida
I have a few 30 MM shells laying around would like to turn them into shifter knobs one day.
But right now the only thing correct on the whole thing is the knobs so they are staying.
