Rifleman
- 2
- 0
- HOT Arizona
Something i found out today while changing my fuel filter. Now you have got to remember i am new to these trucks so some of you guys may already know this trick. When changing your fuel filter the maintenance manual says to empty, then clean the filter housing, next install your new filter into the housing, then install the housing back onto the truck and torque the top bolt to 25 foot pounds. Note, Nowhere in the manual does it say to fill the filter housing with fuel before installing it. Doing it the way the manual says to do it is all well and good if you want to pump that prime handle about 200 times. I found it alot easier to fill the housing about 3/4 full of fuel, drop in the filter element then install the housing back onto the truck. Doing it this way will save you pumping your arm off trying to fill that empty filter housing. Just a side note, that empty filter housing holds about 3/4 of a gal. of fuel, so you can see it would take alot of pumping to fill it using that little primer pump.
