Blown ABS ECU - how not to do that etc.
martinwcox
Wilmington, MA
ABS now Working!
I spent the last few days as time permitted to add the surge protector and a relay so that both the Perm + and Switched + to the ECU are protected.
Swapped out the bad ECU for the new one I purchased on ebay and all is working, ECU self test passes and the ABS Light goes out as it should.
Phew, you never know with stuff from ebay!
M35A2-AZ
423
Tonopah, AZ
Nice job!!
You have any pics and the type and p/n of the surge protector and relay you used.
Also the p/n of the ECU you used.
A friend has the same problem with a M931 now.
Thanks!
74M35A2
342
Livonia, MI
Any updates here of how protection can be added? I zapped my ABS ECU also, and I'd like to add over-volt protection as we'll. It seems the ABS ECU is the only thing to pay the price in an over-volt situation on these trucks. Sure, it is easy to say "Shut it down correctly", but I can't guarantee that to take place every time, correctly. My kids start/stop the truck as we'll.
I have a separate thread started to check known relationships between a properly functioning PCB and the ABS ECU.
