- 7,404
- 2,491
- 113
- Interlachen Fl.
What is hoping like crazy to you. There can be tire hop from the tires or there is sprag hop and when it's sprag hop the front end just about would come off the road. As said with the bigger tires air pressure is you friend. I run 45lb and the ride is not bad but you can feel a little side walll flex in the turns but you get use to it. There is also them problem of high unsprung weight and the tires having a little flat spot from sitting. It takes more then a couple of miles to get this much rubber warmed up to the point they might relax a bit.
Did you get one of the USMC dumps?
Looks good and have fun.
