Bobbed deuce speed
G744
4,143
Hidden Valley, Az
Years ago I was at the USMC base in Yermo, Ca. I bought an M37 on sealed bid. Next to the DRMO yard was the motor pool.
I moseyed over and talked with a mech, and he led me out back to a fenced yard full of hundreds of Multifuel engines on pallets.
All had rod failures with the center web blown out. His feeling was there was a design defect when Hercules copied the MAN design.
He referred to them as 'lightbulb engines, 'cause you never knew when it would burn out'.
DG
Floridianson
2,537
Interlachen Fl.
DG
Yep I never worried about airing the block believe that is why God created the Cummins 6BT and Jeepsinker to show us how to fix the problem.
Dipstick
1,268
Effort PA
There's a lot of good information in this thread. I live in a mountainous area and so there are hills that my Brutus will not pull in 4th or 5th. I usually run my engine to 2,500 rpm before shifting into 4th or 5th, because my rpm will have dropped off too much before I can complete my upshift if I don't. There are some long steep grades that occur just after traffic lights around here. I know I can only pull them in 3rd, so I don't even bother trying for 4th or 5th. I get in the right lane and do 2,100 in 3rd all the way up the grade. Keep in mind my engine is bone stock. It has not been turned up or bypassed and seems to run fine. I run 11r-20s and at 2,500 rpm I seem to run about 52 mph. Maybe my aging eyes aren't reading the speedo correctly.
I previously mentioned uphill grades. Well, there's always a downside to uphill grades. Of course there are traffic lights or stop signs at the bottom of these downhills too. I write this as someone who has experienced a total and sudden loss of all braking while while stopping for a traffic light on a slight downhill. I blew my air horn and managed to downshift to 2nd gear and crawled my way for a quarter of a mile until I could safely pull over and used my newly rebuilt handbrake and a snowbank to stop my truck. I was lucky traffic was light due to an impending snow/ice storm. I mention this to illustrate that I understand the limitations of Deuce brakes and I drive with caution on all grades up or down. I always try to anticipate conditions and drive with the assumption that a traffic light will likely turn yellow or red on my way down a grade. I usually back off the throttle at the top and engine brake down. I never try to beat a light.
As I previously mentioned my Deuce runs 11r-20s. Their maximum rated road speed is 55 mph. I read in another thread, that there is a DOT rule that states " If the maximum speed rating of a trucks tires are limited to 55 mph, then the truck can be driven no faster than 55 mph". Makes sense to me. So taking into account Deuce power, weight, brakes, and suspension design, I drive my Deuce like what it really is.....a military vehicle that is one half farm tractor and one half truck.
frank8003
4,990
Ft. Lauderdale, Florida
Deuce is a nice ride, Go Slow.
You wannah go fast then get a commercial vehicle.
Even the Wifes' grocery getter will do 0-60 in sick seconds.
Even an old Volt is 0-60 in 7 seconds and does well over a hundred using battery.
Multi fuel trucks are a dying breed.
Keep destroying them and ours will then cost that much more. A lot more.
Dipstick
1,268
Effort PA
Amen Frank! Parts for Deuces and 5 tons would be harder to find and much more expensive to buy. It's simply a matter of supply and demand. Long live the Multi-Fuel!!!
Davidwyby
244
CA
DG
Please expound on the "center web"
Thanks!
V8srfun
539
Altoona pa
These are the 2 most used performance dampers I know of. I wonder if they would make one to fit our trucks. they would probably want a cad drawing for actual size specs and I have no clue how to do that.
98G
Former SSG
4,880
...Keep in mind my engine is bone stock. It has not been turned up or bypassed and seems to run fine. I run 11r-20s and at 2,500 rpm I seem to run about 52 mph. Maybe my aging eyes aren't reading the speedo correctly....
That should be about 57-58mph. Speedo is going to read about 10% to the low side at any given speed.
Dipstick
1,268
Effort PA
All had failures between cylinders 3 & 4. Blocks were wrecked.
Dennis
Sounds like a design weakness in the crank, block or main bearing caps at that point to me. The middle of the crankshaft is where you'd probably encounter the most crankshaft flex and strain.
Davidwyby
244
CA
I think it's usually rod failure...? There are improved rod bolts now.
cattlerepairman
3,523
NORTH (Canada)
I agree with you. Weak rod bolts could definitely be the cause. Good thought!
The weak rod bolts (regular hex head) were in the past credited for many connecting rods escaping to the outside of the engine block. The recommendation from many threads on this forum has been to drop the oil pan and replace them with the stronger 12 point ones, available for Oliver/White 130/150 tractors, if the military had not done so in a previous rebuild.
Sent from my SM-G950W using Tapatalk
