- 14,706
- 5,111
- 113
- Buchanan, GA
You're already walking on thin ice at 20psi. I will bet money that you'll lift the head at 30psi due to the high CR.Ive been thinking about swapping in a detroit for a long time now. However I just said WHAT THE HECK ill just see how much this little baby can put out. so yesterday I went and got a boost gauge, already had a good digital pyro. I CRANKED the fuel up like 7 flats of the nut. she ran very well but still had some wiggle room. So I cranked it another 4-5 flats and now i get 20 psi of boost at 1150 EGT smack dab behind the turbh and I had already cranked the fuel up a bit before that. Anyone every put a big turbo on a deuce? like a detroit diesel turbo much like the one pictured?This turbo is AT LEAST twice as big as the deuce hair dryer. Im thinking of doing that with an Air to water cooler setup from here http://www.frozenboost.com/product_...=1007&osCsid=cf57e9e804308d03b551f49a0696078f. should be able to do a cable on the FDC to control boost and egt's with an aftercooler it should keep the egts down and be able to produce around 30 psi pretty easy. much more than that I think I might blow the head off the poor girl.
View attachment 483876View attachment 483877View attachment 483878
Bigger turbo isn't always better. A turbo with the proper map to operating range is best.
