Bringing the Deuce back to 100%
cattlerepairman
3,503
NORTH (Canada)
I like the choice of lights but I am not as brave as you when it comes to the mounting location. I would be worried about what the winch cable is going to do to them.
shannondeese
19
High Springs Fl
I thought about that but if I mount them on the bumper they are in the path of the head lights. So I end up with a pretty good sized shadow at about 15 ft out. I almost mounted them on the fenders but they are very short range flood lights. So workable light output is really only about 20 ft. Still it's a lot better than not having them. When I add the ones to the side of the truck tomorrow it'll be a lot closer to the ideal recovery and off road vehicle mobile repair station I envision.
shannondeese
19
High Springs Fl
Today while doing a little PM on the Deuce I found my coolant hose going to the heat exchanger was cracked and split. It wasn't leaking but was very close to failing. It was an easy fix. About a year ago a friend of mine rebuilt my steering gear box while I was deployed. Today it started sticking after I turn left again. So I am going to replace it here soon. I am going to go with a power steering option but I haven't figured out which type I'll go with yet. Cost is a very big part of that equation. Also this weekend I am going to pick up the new air conditioner for it. Cant wait to get that installed.
tk748462
Big Rapids/MI
When you fixed your passenger window, did you have a hard time getting the assembly back in the door? I tried to fix mine on the driver side, but I must of had something wrong, the part where the knob screws on the the assembly, it would catch on the inside of the door. I got mad and threw it 30 feet out in the yard and now it sits in the back of the truck. lol. sure would appreciate any tips, thanks!!!
shannondeese
19
High Springs Fl
Today I am going to attempt to fix my passenger side window motor. I can hear it moving but the wiper arm won't move. If I turn the lever manually the wiper arm doesn't move either. Hoping it's something simple. I doubt it though.
shannondeese
19
High Springs Fl
A few weeks ago I changed the hose going behind the oil filters because it was bulged and about to blow. Last night on the way home from work the new one blew. I was southbound on the I5 right off of Camp Pendleton. What a joy that was. My wife brought me another spare I had sitting in the garage and within a 30 minute period of getting the parts we were back on the road. At least by the time it was done the traffic wasn't bad it took her almost 2 hours to drive the 40 miles from our house to where I was.
shannondeese
19
High Springs Fl
A couple things done
Today I got pretty busy on the old girl. I rewired the horns so they work again. I braced the passenger side mirror so I can see more than the ground or sky depending on road speed. I installed a windshield washer bottle. I finally mounted the trailer wiring plug too. And I put the bed side extensions on I've been holding onto for a couple years. A lot left to do but getting closer.
