Broken AC drain line
504GNG
New Orleans, La.
Recently purchased a first HMMWV M1161A1 and the condensate drain line from the AC over the passengers leg area is broken. The piece in the hose is a standard barbed nipple/ male piece, but I am not sure what the other side's connection is supposed to be. Did that side break off of the housing of the unit or is there another male piece stuck inside of the housing?
HoveringHMMWV
1,367
AL
To me, it looks as if the male piece has broken off of the condensation drain pan case. May be able to remove the pan for repair with an epoxy or simply replace the pan. Removal may be challenging in that confined space where you can't see the mount points.
Milcommoguy
2,402
Rosamond, CA
NO expert on this BUT.... looks to me you have enough material to tap some threads in it (plastic or metal ?) then screw one of these in there.
May have to take some threads off if threading it all the way in... to get it flush to the inside for proper draining. JB weld the , heck out of it.
Tap, glue, screw and hammer, CAMO
thoner7
235
NE TN
I have the same issue and cannot seem to get a water tight seal, while working only from the outside of this panel.
move looked and cannot find a parts breakdown of the evaporator. Does this front plastic panel come off? So that I can get a water tight seal from the inside?
DREDnot
586
Phoenix, AZ
That part is integral to the whole front half of the housing and cannot be removed in place. The plastic shell is absolute crap with the structural strength of an ice cream cone. The best fix ive used is to lightly thread a brass barb fitting in slathered with RTV to mimic the original and replace the drain hose with rubber or vinyl that is more flexible than the original to have less stress on the fitting. Sorry, no pics of the fix, just from the first one I had apart
thoner7
235
NE TN
That’s what I feared. I have threaded in two different fittings with a snug fit. Tried two kinds of sealants. Both leaked. Ugh
