stevemcgee99
- 8
- 3
- Seattle
I don't know if it's related, but sometimes my Gen 2 light flickers, moreso at idle.
And the water in fuel light flickers some.
I drained water/fuel out of the filter. Seemed to be OK after that. But then the fuel gauge started dropping rapidly. Went to empty but I had plenty of fuel.
No glow plug, no warning lights (except for Gen 1 and 2) on start up.
20A fuse for ignition was burnt. Replaced it. All was back to normal.
Next day, water in fuel started flickering on again, just a bit. Then fuel level showed lower than it should.
Stopped, and when I went to restart none of the lights came on again.
I'm sure I'll find the fuse is burnt (it's opaque version so I can't see...).
What might be causing this?
