Busted block
rustystud
3,273
Woodinville, Washington
008 (2).jpgMine was bolted. I had to remove the front spring to get access to the bolt heads though. I had removed mine to weld on a piece of 1/4" angle to the front of it for extra support as shown in PM magazine.
welldigger
Benton LA
I believe mine is like rustys but I haven't even seen my truck in a month. If it's bolted I don't see why you couldn't remove it. Although, I can see it being a royal pain to get to some of the bolts.
Jeepsinker
467
Dry Creek, Louisiana
So has anyone swapped cross members from the riveted type to the removable type yet? It doesn't look too hard to do but I haven't really inspected both setups real closely to be fair.
rustystud
3,273
It can be done, you just have to remove the rivets and install grade 8 bolts. Of course that was easier said then done !
tco3129
Flat Top W.V.
I got my new gantry crane assembled today. Bought a load leveler and chain fall. Hopefully the weather will break long enough to start pulling the engine
73m819
327
gainesville, ga.
You do not need to pull the pan, they changed out Andy3s engine at the 14SSGAR (2014 Steel Soldier GA, RALLY), pulled the engine/trans as a unit, did NOT pull the cross member or dropped the pan.
gimpyrobb
dumpsterlandingfromorbit!
27,786
770
Cincy Ohio
No, you don't need to pull the pan, but it makes life easier. If you pull the motor and trans as one unit, I'd pull the top of the trans off too.
