ianfotheringham
- 0
- 0
- Toronto
The helical gear fits the transmission 3rd gear IIRC, the other gear on the US pto and the Acme pto is square cut and runs to the slider gear in the pto. The Chelsea would have a different design, Not being familiar with the Chelsea S or seeing an exploded view makes me wonder how it is disengaged. I will look at my Acme t98 and check the other casting numbers you posted for it. If it is an Acme T98, then the Chelsea S would be worth further investigation. Did it fit in the driver side opening on the transmission.Similarly, this is the pto that came off it, made by Chelsea, model S, oriented to the rear for a chain drive winch that had been mourned in the bed, tow truck style... Wondering why both gears are slanted, where the factory pto had one slanted, one square....? View attachment 547263View attachment 547264
Excellent to know there's help out there... Got to love the Internet... Ate you talking about Brian Ashby? Looks as tho I'll be trading that pto, the tranny and some other bits to guy in Ottawa (Marc?) for some windshields a steering wheel and some weatherstripping, but will get your a better pic of my pto, just sandblasted this morning....Thanks, I have been on a long quest for either parts to repair or replace the Acme pto idler as its the only part difference from the US pto. It was in aid of another friend in Churchill Manitoba who had a transmission failure and broke a tooth on the Acme pto. After a lengthy and fruitless search, I sent him the idler gear out of my pto and it was used as the master to produce another gear somewhere in the US, south of Ontario. None of the gear cutters out here on the west coast were interested. Unfortunately, that new gear ran noisy and eventually I found another take out pto locally and Bill made a reasonable deal for it. Your Chelsea is the only one I have seen or heard of used on an M37 so is of interest as an alternative. Facing the rear may be an issue but there may also be a forward facing version. Finding one is another challenge. Once we figure out where all the CDN parts went after disposal, there will be a few idler gears and then the problem will be solved as a US pto could be converted.
Thanks for the information. I have some experience and contacts for M37CDN stuff, so let me know if we can help. Also, join us over on the G741 Forum as there are a few of us Canuks over ther and it is an all M37 site. Some of those that frequent this site also get over there from time to time. Parts in Ontario are available locally. PM me for the vendors name and contact.
Jess
