can you put 52" tires on a Deuce
4,630
You'd have to lift it as well as bob it to get 52's to fit. You can squeeze 47's under a stock deuce.
PaFarmer
35
PA
Clark is a member here and built that lifted bobbed deuce. It was taller than it was wide, but he ran it on tough trails at Rausch Creek and it worked great.
PorscheTech911
Kearney, MO
52" are just to big IMHO. They look dandy on a 5 ton though. The deuce is just a little to small/underpowered for something like that. I also prefer the dual rear look though. I think 14.00x20 duals (that may not be correct) are what I like. See picture:
davidkroberts
22
west tennessee
i helped build the Ga to Va truck with another list member on here. We used the USA 6x6 rims so im not sure of the backspacing but we didnt lift it an inch. The exhaust tube has to be rerouted as the tire will eat it in turns. The truck will not perform worth a crap but it will fit and we wheeled it through some pretty rough stuff and didnt get into the fenders.
IMHO you need to stick with the 395's max and use a lockout hub.
