CDR Hose
O.D. Fever
Howard City, Mi.
I have searched until I am blue in the face. I need the rubber hose that goes to the bottom of the CDR valve part # 14050446. I searcher the part number and came up with nothing. I found an old thread and that poor guy also came up empty. Mine is ripped wide open and my rear main is leaking. I will put a new main in after I find the part and it still leaks. Any help would be great. Thanks Joe:???:
O.D. Fever
Howard City, Mi.
Yes thats the CDR, I need the hose on the bottom, the one you can't see. It takes the two tubes from the intake and joins them to one for the valve.A Y hose.
ralbelt
9
West Warwick, R.I.
Yes its a spark plug, I have an open plane intake manifold and it only uses 1 breather pipe from the CDR, a spark plug is the perfect size to seal the second hole, Plus it keeps you guys on you toes, eventually I'll attach a coil up to it to really mess with you.
ODdave
lansing michigan
Did you find the hose yet? I can look today and see if I have one if you still need it. Headded out tthere in a lil bit.
