CDR Valves No Longer Available
AJMBLAZER
Paducah, KY
I believe the 6.2L HMMWV uses a different CDR valve...maybe? At any rate, I bet the military has a couple zillion of them sitting in a warehouse somewhere.
Then again they are phasing the 6.2L trucks out of the inventory or converting them to 6.5L.
Milkman357
15
Des Moines, IA
CDR valve...
I've been reading about CDR Valves....
Seems some say they anrt needed....just bypass with rubber tubing...
On a Ford Forum whatever diesel it was (A newer one) had to have it. They recommended cleaning with Gasoline...not solvent...every other oil change.
What is the opinion of Steel Soldiers?
I think I read somewhere if your Piston rings are in good shape it's not an issue.
As they wear, and blowby increases that's where the problem occurs...
Either way there has to be a suitable alternative.
a68cudas
Brookfield, Ohio
Stonepicker1 told me that it could be done. As far as what solvent, and how many times I dunno. Sounds viable though. Perhaps let it soak in odorless mineral spirits, blow it out/let dry, then reinstall? :confused:
I know ive cleaned a egr valve out and also an iac valve on a s10 blazer, and i have always used can of carb cleaner to clean those out with
1,193
A cdr valve has rubber in it, do not use carb cleaner.
REGULATOR
Martinez GA
Sooo where are we at with this? and technicaly is this an emmissions item aren't they supposed to make them for a number of years to come then?
Or is it they are ONLY available now from GM dealers?
and the HMMVW with 6.2 used the same valve, I swapped an engine from one into mine, but think the oil consumption in my M1009 may be attributed to the CDR.. was hoping to buy one and see.. but sheesh they are becoming rare I guess?
going to check local CHevy dealer wondering if I still have one from the old engine.. might be sitting inthe scrap pile from the swap..
guess a trip to Napa or Autozone would be a waste of time or maybe they might have one laying on the shelf... covered in dust
AJMBLAZER
Paducah, KY
Dig dig dig and find a 6.2L CDR valve. If not, 6.5L valve cover and use 6.5L CDR valves.
No, you can't clean them. GM and the military say that's a no no and that yes, you need them.
GM dealer, maybe military surplus, or do the 6.5L valve cover conversion.
Sorry, no easy answers.
REGULATOR
Martinez GA
Id take one or two if you get some in...
don't want to be too greedy.. and I hate the thought of outbidding somebody on ebay that might really need one worse then me, or not have the money...
But I'm away from home right now, and I 'm not sure if my 16 yr old would be able to navigate the napa or autozone route, and would probably not survive a trip to a Chevy/GM dealer alive...
so want to order some and have it shipped to him, seems liek he'd be able to swap it out and see if it runs better, if not, keep the old one on standby it might still be good enough...
m38inmaine
102
Maine USA
I am still getting payment for these and I sold out long ago, sorry I don't have anymore. Again SOLD OUT of CDR valves.
