- 2,177
- 50
- 0
- Butler TN.
Small cars work good too!for a 5t I would use at least a 6"x 6", a 8"x"8 or bigger would be better to make wedge ckock blocks
![A toast to MV's :beer: :beer:](https://www.steelsoldiers.com/images/smilies/beerchug.gif)
OTHER things work just as well for 5ts but my kinder/gentler self has to reframe so as not to hurt feelings,Small cars work good too!![]()
The yellow wood one is 14 inches long, 5.5 inches wide, and 3.5 inches tall. The rope is about 3 ft long (3/4 inch dia.)Can someone please give me dimensions of the proper 5 ton chocks - I have pics of wooden ones, but didn't take dimensions. Or pics and dims of the steel ones... Including the chains too.
Unless someone has them for sale in the North East.
Thanks in advance.
I like that but you need to start with and copy an existing chockIs this what you want?
Wow, it is an F-16 Chock, and yes an F-16 can jump the chocks as well as any of these trucks, but it should hold against gravity assuming you are not pointed down a serious hill side. I also see old "F-16" chocks used all the time for trucks albeit none as pretty as my shinny new one.Thanks Mike, but I don't think the "F-16 chocks" you posted earlier are big enough for a 36,000 lb wrecker (+ any vehicle it has on tow). Some one else posted that their 5 ton rolled right over some low chocks.
I am looking for the correct, BII (though they are not in the TM posted on SS) chocks that were issued wit hthe truck, in Olive drab, with painted on MSN #. The ones I saw, and got camera pics of, were at least 6" high, with a long chain that goes up to the bed side.
I have homemade ones that work, not a military pattern though, but I would like the correct ones.
Thanks again.
Actually this is the correct chock UNTILL the 1400s came out on the 939 A1 and A2 series trucks, The correct chock in service for that series truck and larger is an oak chock, that looks almost exactly like the f 16 chock and close to size, PM me if anyone wants the exact correct measurements, I have a few to measure for U, But the fast difference between the F16 chock is No rope, no cut out for rope, just an I hook screwed into the center of one end, then the mil style cheap chain, with a dog leash looking end that hooks to the side of bed loop, chain is about 6ft, just like the older style crane truck pictured... """ >>> BUT I will add the chocks dont come with the chain for the 939 series with the 1400 tires, just the chock, so U will not see the chain on most in service...But both with and with out chain would be mil correct,Is this what you want?
