She's sittin at the gate at Jack's at the moment. I have the K30 (well most of it) sitting on my trailer at the moment. I suppose, I should work on it today. I really want to open up the new Dana 60 and check the bearing surfaces, though.
I have a lot of irons in the fire on this one and not a lot of time to complete it. The turbo conversion is going to take up a chunk of time. I would not even bother but I want the boost (pun intended) in efficiency. My research, so far, shows 5-10 psi and +/- 1/4 turn at the IP to be a practical setup for a stock 6.2. A thicker 6.5 head gasket may allow 15 psi. I am looking for balance however, so for now the plan is stock 6.2 with a stable tune. I will have the boost and pyro gauges, but I don't want to have to eyeball them constantly on long pulls.
The perennial question, that keeps haunting me, is turbo, dual 60s, 4.10s, 35s, and a body saw; or turbo, dual 60s, 3.55s, and 285/75r16s. The prior, at this juncture, may actually be cheaper. The outlying factor is the lack of traction modifiers and the unknown condition of the rear 60 (The backlash seems high). I could live with an open front, for a while, but I'm not sure I'd remember how to drive a one wheel drive truck anymore.
I'm having flashbacks of being stuck behind the barn, on a shallow grade, with DEW on the grass, spinning the tires helplessly on an '86 one wheel drive Ford dually, with the 6.9 humming out a lurid cadence. Queue the 1980’s, teenage horror flick, axe-murderer chase scene, but not really running, scary music.
Either way she’ll likely end up with a locker in the rear (Detroit/Grizzly) and a limited slip (TrurTrac) in the front.
Then there is the problem of tire selection in Florida. Sticky mud and sugar sand, are you kidding? I’m leaning toward a KM2 or Xterrain with 8-10 psi. Hopefully, with the winch and OBA, I won’t be sitting stuck too often.
But, I digress.
