Cleaning Inner Axle Funk- Dana 60.
Zero_cool
Virginia,Minnesota
Have you checked out the TMs yet?
JATONKA's CUCV TM download page
TM 9-2320-289-34
Paragraph 6-8
page number 6-41
Tells how to do it with housing spreader.
Allot of the steps are unnecessary such as removing the axle and placing it on a stand etc
Basically all I did was remove the 4 bolts and pryed it out with a bar. I noted which parts went on witch side for installation.
ODdave
41
lansing michigan
FWIW, I did not see it mentioned so i figured i would throw it out there.
DO NOT MIX THE BEARING CAPS UP. They are marked, If you look carefully at the cap you will see a letter (usually K, 0, or P) stamped in them. one will be up right, the other on its side. Its mate will be stamped the same way into the gasket surface on the housing.
bushhawg73
Columbia, Missouri
ODdave is correct about the stamped caps. Once I found the markings there was no messing them up as long as you place the cap the same way as the letter is stamped into the cap and housing. Mine was a royal pain in the rear to get in. A case spreader would have helped a lot. The fact that the carrier and ring gear are really heavy and cumbersom does not help at all. You can see the letter Y stamped into the cap and housing.
that1028guy
Florissant, Mo
I feel pretty lucky. When I rebuilt my front end on the 08 it took a little pry bar to get it out and was not a pain to get back in at all. As far as cleaning the inside, you can put the hubs back together, and shove some shop towels in the inner berring side of the wheel and put the brakes and wheels back together and take it somewhere that has a heated pressure washer, and soak everything in degreaser, then blast it. But make sure to rinse it till the waster comes out clear so there is no degreaser left in it. Then I used brake clean and wd 40 to wipe everything that needed to be dry and rust free down before reasembling everything. May seem a but extreem, but when gear lube mixes with sand, it turns into concreete, and i was not putting it back together with all that crap in there. Hope this helps.
