When I got my deuce, I noticed that the clutch engaged near the top, too... I also had the free play correctly adjusted. Looking at the clutch disk through the inspection cover, I thought it looked thin, and so I thought it was worn out. I didn't want to get stranded somewhere, so I replaced it along with the pressure plate, pilot bushing, throwout bearing and I had the flywheel surfaced.
My first observation was that the old disk looked exactly the same as the new one - No discernible wear, and a micrometer showed less that .030 difference... But I went ahead with the replacement since I already had it apart and had the new parts in hand.
After the replacement and adjustment was finished, there was no difference in performance at all! The expensive and time consuming lesson I learned is that it's normal. As long as the free travel is adjusted correctly drive it until it starts to slip.
Jon
