combat rims
beastm35
plainfield ct
Hello all before I buy them does anyone know forsure that 1400x20 goodyear at2 will fit on the rim? And then go on a bobbed deuce. The tires are on a regular deuce rim with split ring now. I have heard that's not safe so I finally found combat rims is this the right move or not??? thanks
SETOYOTA
419
georgia
What do you mean combat rims? Bead locks? Regular deuce wheels are lock ring not split ring. There is a big difference lock rings are perfectly safe if handled properly. With that being said I would not run 1400s on them. I know many have with no problems.
Jbulach
2,056
Sunman Indiana
I think you want A3 wheels or MRAP wheels with adapters. I don’t think anyone is making combat wheel adapters anymore?
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Lots of folks call all different rims, different things. Please post a pic of the rim in question.
If it is only 7.5 inches wide, it is not a great idea to put 1400s on it. The A3 rims(or any 10/11 inch wide rim) should work just fine though.
