- 5,779
- 3,237
- 113
- Metairie/La (N'awlins)
some of the mrap's are aluminum
I know this is old but I am putting 16's on HEMTT rims on my M923. I's rather not change wheel studs up front and I hear the lug nut will be shy of full thread contact. Thimbles? Is that whats on the rear wheels of the M923A0?Yes, 53 inch tires on Combat wheels will rub on a five ton. I had to add 1 1/2 bridge truck spacers to keep the tires from rubbing on my steering arm and hydraulic piston cover. you will need to change you wheel studs or do thimbles on the from if you run HEMMT's.
Hello from Greece.
Does anyone knows the weight of the standard HEMTT wheel (tire+rim)? And also is wheel balancing necessary to the HEMTT tires?
that is not good...what is the problem fitting them to a 5ton? offset or bolt pattern or both?Only the m35 with adapters. Useless for 5 ton
