- 12,195
- 319
- 0
- gainesville, ga.
Just give me the compressor, that will solve all the argument
Because three phase motors don't need start/run capacitors. Each phase is 120 degrees offset which automatically rotates the field.Yep, mine does not have a capacitor on the top of the motor like your's does. Thanks for the pic.
Dave,
I guess I should have clarified, THERE IS NO AVALIBLE 2phase CURRENT, But it your motor, your garage and your LIFE at stake. If you think you can wire a 3 phase motor to run off single phase have at it. I cant stop you from thinning the gene pool.
I agree with you, and I say the same thing when I here people talk about something that I've been trained in, and basically all they are doing is regurgitating something they heard third-party. But you contradict yourself. You say on one hand only a licensed electrician should touch any wiring, but then you say the inspector, who is said type of person, probably doesn't know what he is looking at. The wiring I've done is all very basic - light switches and outlets. If I want to do something more, I'll call a friend and trade some automotive work for his electrical knowledge (he's a licensed master electrician). I'm not trying to build a power plant here, and I'll bet even you have made mistakes and lived to tell the tale. Whenever I wire in a new circuit, I have my tester and make sure everything is right before I touch anything. Afterwards, I test it all again for any sort of phase to ground or other faults. It is not rocket science, but I find it interesting as all getout as I learn what I am doing. You seem to think I should not be allowed to learn about your coveted trade unless I do it exactly as you did. There is more than one way to skin a cat. Notice I started this thread and still have not attempted to actually do anything yet? I learned a long time ago to be sure I know exactly what I'm doing before I give it any juice. I also don't skimp on material like many of the electricians do to save a buck. You won't find anything less than 12 awg wire in my buildings and most of it is size 10 or 8. Also, the big stuff is wired by a professional, so you can get off your soapbox now."it passed all the inspections" is no indication of proper wiring, it merely indicates the level of knowledge (or lack thereof) of the inspector.
I've reinspected previously passed jobs and found mistakes that have caused red tag and lockout/ tagout to be used. One reinspection was performed as the result of a fire that destroyed several milling machines.
Why do people think they can read something online and magically become an electrician?
There's a reason the apprenticeship program exists as well as the testing and continuing education.
I understand a lot of electrical stuff and know some of the code quite well but I know enough to understand my limits and when I am not sure I call a licensed electrician that I know
It is not true 2 phase power, the household suff we are familiar with is just a center tapped tranformer , if You put a meter across both hots it is still only 1 phase.. but in referance to each other , yes they are 180 out of phase, but real 2 phase would be 90 out of phase.Dave,
This may be an argument of semantics (and I have not read the whole thread to know the background behind your answer) but split phase is two phase power. .
No, it is not the "90 degree 2-phase" system referenced in your article and I realize that it is "incorrect" to refer to split phase as 2 phase. This is unfortunate because split phase has more in common with 120/208 wye than the "2-phase" oddity.It is not true 2 phase power, the household suff we are familiar with is just a center tapped tranformer , if You put a meter across both hots it is still only 1 phase.. but in referance to each other , yes they are 180 out of phase, but real 2 phase would be 90 out of phase.
2 Phase Power Systems and Two-Phase Electric Solutions
You'd be surprised at how many electrical inspectors are NOT electricians. In most places it isn't a requirement, you just have to pass a test.I agree with you, and I say the same thing when I here people talk about something that I've been trained in, and basically all they are doing is regurgitating something they heard third-party. But you contradict yourself. You say on one hand only a licensed electrician should touch any wiring, but then you say the inspector, who is said type of person, probably doesn't know what he is looking at. The wiring I've done is all very basic - light switches and outlets. If I want to do something more, I'll call a friend and trade some automotive work for his electrical knowledge (he's a licensed master electrician). I'm not trying to build a power plant here, and I'll bet even you have made mistakes and lived to tell the tale. Whenever I wire in a new circuit, I have my tester and make sure everything is right before I touch anything. Afterwards, I test it all again for any sort of phase to ground or other faults. It is not rocket science, but I find it interesting as all getout as I learn what I am doing. You seem to think I should not be allowed to learn about your coveted trade unless I do it exactly as you did. There is more than one way to skin a cat. Notice I started this thread and still have not attempted to actually do anything yet? I learned a long time ago to be sure I know exactly what I'm doing before I give it any juice. I also don't skimp on material like many of the electricians do to save a buck. You won't find anything less than 12 awg wire in my buildings and most of it is size 10 or 8. Also, the big stuff is wired by a professional, so you can get off your soapbox now.
What that has to do with electricity is a mystery to me.Here's something to think about for you, AN/ARC186: You say in your signature you own seven very spoiled horses. I'll bet you can't tell me what a pineal gland is or where it is located or how it is used in the race-horse industry without either looking it up on the internet or asking someone like your horse vet, so does that mean you should not own any horses?
It's called an "anology", and it is quite common for people to do this. My point is you don't have to know everything a veterinarian knows to own a horse and be a competent horseman, just like I don't need to know everything there is to know regarding electricity, or be a licensed electrician, to install a simple wall switch or outlet, or in my case, a 125-amp panel with 5 circuits. Don't stay up too late watching for the fire, you need your sleep. If you are not part of the solution here, why don't you not be part of the problem. Keith was helpful with his posts, as were several others, but really, I started this thread because I wanted to learn a little more about this 'magic' of electricity, and you come on here lecturing me about stuff I already know. I already have a mother and I already have a wife, so I really don't need anyone else to monitor my actions. In other words, this is an A & B conversation, so if you can't contribute in a positive manner, how about C'ing your way out the door?What that has to do with electricity is a mystery to me.
and if I need info on our horses I just ask my wife, who has more knowledge about all things equine than I ever will. I just clean stalls and repair fences.
so now that you've made your completely off topic remark, please continue
Well, this one is a licensed electrician, and he is very competent in his field with a great reputation in these parts. I also have a cousin who owns the electrical contracting firm that takes care of the whitehouse in D.C. If I'm really stumped, I can always call him. I'm just really stultified how when I ask if anyone knows how to convert a 3-phase motor to single phase, it is like opening Pandora's box with some of you guys. Save the lectures for your kids, dogs, or horses. If you have useful knowledge to share, then by all means, let's hear it.You'd be surprised at how many electrical inspectors are NOT electricians. In most places it isn't a requirement, you just have to pass a test.
Sure there's more than one way to skin a cat, there is also a right way and a wrong way to install wiring.
Thanks, but I'll stay on my soapbox, it'll be much easier to see the fire at your place from there.
