- 1,921
- 1,191
- 113
- Paris KY
I have searched and searched but to no avail.
I purchased a new mechanical fuel pump for my M1028, however I must have got the wrong one. My GM book indicates the correct replacement pump should be AC Delco 43-254, however there is a a difference in the inlet tube which will not let this pump fit. On my original pump, the inlet tube comes out of the bottom of the pump and turns towards the front of the engine. However the new 43-254 pump's inlet tube turns towards the rear, which will not work beccause the tube actually hits the frame. There is absolutely no way to attach the rubber fuel line and get it low enough to bolt the pump on. I wouldn't want to do this anyway, because sooner or later the frame would wear a hole in the hose.
Has anybody else encountered this issue? Did I get the wrong pump?
Thanks in advance for your help.
