silverstate55
Unemployable
- 2,130
- 1,090
- 113
- UT
Very nice!!
That's a great idea Chris,I will do that!I would have thought you'd put a Ubolt there to hook to Ray, thats gonna mess up the paint if you keep hooking on as shown in the pics.
Sweet, what kind of crane is that, any description of the building procedure?
How do you pick one up, as in:For those not yet in the know, the V3S is the Czech version of the Deuce, with an absurd short cut-off nose and small engine. They keep moving forever, and are now often used as farm trucks or by small rural building companies.
Hi Robo . I did a little write up on the build search for " crane on a 925a2"
I ran a search and couldn't come up with it.Sweet, what kind of crane is that, any description of the building procedure?
If you find it, can you put up the link on here, please?
I've actually seen that done on a civilian two axle trailer. There is a crane company out here that has one. It is a bit bigger then two tons though.i had a amusing crane idea ill bounce off the hive mine and see if it sticks, how about basing the crane out of a 105 trailer? 4 folding outriggers with adjustable feet and 24v power it off a slave cable so its self contained with the pump on the trailer, being hooked to the truck would lend a bit of stability too. i kinda want a crane but really want/need a dump bed and those two don't exactly get along if the crane is couple ton able, maybe a autocrane or something else scavengeable of the same class that can be based off a pedestal and has power rotate
I like your idea of having two cranes like that ! Did you need to add a plate under the one on the bed ?I must has forgot to post my pictures here. I still need to make a pocket for the front bumper mount...View attachment 751561View attachment 751562used parts of an old engine hoist with a bad cylinder that was given to me. Bought a new air powered cylinder from Harbor Freight.View attachment 751563View attachment 751564Also added a small winch.View attachment 751565Load tested to 1000lb.View attachment 751566View attachment 751567Can almost use it to pull the head.
