crossmember/ tansmission mount
MrBouncer
Grays Creek NC
I was told that my transmission mount/crossmember was bent, that it should be at leat 13/16 higher on the ends than in the middle. Mine is about that on the drivers side but almost even with the middle on the passenger side. I need to know if what I was told was accurate. I cant find a full picture much less dimisions in the TMs. Any help is greatly needed and appreciated. always
Zero_cool
Virginia,Minnesota
sorry i cant find my stock crossmember to take pics of, to much crap in the garage, but yours does look bent to me. I think a little heat and she will straighten out pretty nice.
good luck
dan
DokWatson
Wasilla, Alaska
That crossmember is extremely bent. It should sit flat on a level surface, with the ends that bolt to the frame being slightly raised. I wouldn't bother trying to fix it, you can find one at a junk yard.
