Ronmar
- 8,252
- 113
- Port angeles wa
The stock sensor is a 100PSI, 0-5V. The controller is looking or adjusting the pressure in highway to get to the return voltage for 55PSI, which is 2.75V
if you install a 150PSI sensor, when the controller adjusts the pressure to get that same 2.75V out of the sensor, the required pressure to do so is now 82.5PSI...(55% of 150) so you are looking for a 150PSI sensor in that connector style.
there have been a couple discussions on this, some of those may have P/N’s...
