ccf460
- 1
- 18
- granite falls/N.C.
My 1009 is starting fine, idling fine, but on the pedal produces alot of
black smoke, and not much power.
So far: new air filter, cdr valve was replaced approx. 1500 miles back,
thought it was the fuel filter so I changed to a spin on unit from a civilian
6.2 truck. Cleaned the fuel return check valve (it looked fine).
A little more history, I was running a 60 wmo/40 diesel mix,the problem started on the way home in 95 degree heat. I siphoned out the tank. Added 4 gallons of
fresh diesel from a can. Drove to a fuel station 3 miles away and the fuel cap was under vacuum? Added 10 more gallons drove the longer way home , (7 miles)
no repeat on the vacuum on the cap issue. I had been running the wmo mix for about 1200 miles with no issue, though it was the problem,but removing it
from the equation has not changed the symptoms. Please help!
Oh, it is an 85 with 65,000 on the clock.
