JasonS
- 200
- 63
- Eastern SD
Can you post a pic of the broken block?
I put a remote filter on a smallblock chevy. It is a little smaller than the filter base, but not by much.
Tapping the oils holes might be the way to go. Make sure you use a good filter if you do not have a bypass. I run wix or K&Ns, on my truck with no bypass. I also make sure it is warm before I run it hard. Lesser filters can come apart internally or explode do to too much pressure and restriction.
Use a ford/ chrysler filter with the bypass built in.
