Cucv fuel problems
tbearatkin
24
SouthWestTennessee
I went through it all hoping it was not what I thought it was.
Replaced lines looking for air leaks
Replaced fuel filter bled all air out of the filter.
Checked return valve on Injector Pump.
Replaced fuel pump (twice cause I cross threaded the fitting the first time)
Bled all air out of the system again.
I did not turn up my Injector pump because if it was going bad then I was going to replace it. Nothing like a temp fix only to have it break when you least want it to.
Then replaced my Injector Pump and it runs like its new. I did not replace it myself but paid a mechanic for this.
http://www.steelsoldiers.com/cucv/76410-think-my-injector-pump-shot.html
natem
14
freeland/michigan
Check all your wire connections. You may have a power problem at your fuel shutdown. Make sure you have 12v or more at the front battery. And 12v + at the shutdown.
