CUCV-II, South Florida Rebuild
Stonepicker1
110
Coconut Creek, Florida
Had to replace the passenger side battery. Had a bad cell.
This is the second battery that I have bought from TSC that have not lasted longer then 8 months. no more.
Before I always used Red Top batteries and never had a problem. I have Yellow Top's in my LSSV now and will start buying them for the rest of my fleet.
trooper632
Utopia, TX
What about Walmart batteries, That's all I use, full 3 year replacement at any walmat in the country, or Sams has Energizer batteries same warranty. I have had to switch out maybe 2 batteries out of around 60 near the 3 year end of warranty. Took it back and replaced without a problem. $88.00 for the battery when purchashed, I always thought the Optimas cost more?
Stonepicker1
110
Well the water pump is leaking out the weep hole.
Just ordered a new pump from SSDiesel. Should have by the weekend.
That seal I installed in the rear main might be leaking. Hope I don't have to drop the Trans.
Stonepicker1
110
I had a problem with the batteries going dead after a few days of not being started. Hooked-up the scanner and said I had a short in the lighting system.
I had a new light switch on-hand, so I swapped it out just to see if that would work. Only took 5 minutes to do. Not so lucky. Still had the problem.
Next, I changed the Blackout drive switch on the dash. That fixed it.
I didn't start the truck for 24 days just to make sure. Truck started right up.
So, looks like I fixed the draining the batteries issue.
Stonepicker1
110
The truck stalled on me the other day coming up to a red light. It didn't want to restart. It was running a little ruff like it wasn't running on all the cylinders.
I hooked the scanner up (AutoEnginuity)and it came back as " lost signal from PMD"
I thought it might be bad fuel, plugged fuel filter, or even the optical sensor on the injector pump. But looks like the PMD went bad.
I replaced the PMD( Pump mounted driver) with the gray spare I had and the engine is running like new again.
I mounted the PMD in the engine bay to test it out, I will be mounting it behind the front bumper later.
Stonepicker1
110
Started the truck this morning after the long trip to Iowa and back. Had fuel leaking under the truck.
Opened the hood and fuel was spraying out the side of the injector pump. Looks like o-ring failure on the side cover. Screws were tight.
I took a side cover off a used spare I had and it fixed the leak. Tight area to work. Glad I didn't have to remove the pump.
Warthog
245
OKC, OK
Hey Phil I have a torx bit and wrench combo just like yours, makes it a tiny bit easier to work on the IPs
Stonepicker1
110
Well it happened again. My transfer went out.
Back in June of 2012, I picked up a load in Ohio and was heading back to south Florida when just outside of Macon, GA my Transfer case failed.
They don't make the transfer case anymore( Borg-Warner 4401 ) , so Chevy dealer ordered a rebuilt Jasper transfer. $2,400 and 4 days later. I was back on the road.
Now that transfer has failed again. I had to place the transfer in 4Low to get it to move. Drove it that way for 13 miles to get it to a safe place.:(
Another Ahab
4,903
Alexandria, VA
They don't make the transfer case anymore, so Chevy dealer ordered a rebuilt Jasper transfer. $2,400 and 4 days later. I was back on the road.
That stinks. Sorry you had the problem.
But maybe the good news was crawling like that there was no speeding ticket in your future over those 13 miles. :mrgreen:
transman
mildred Pa.
4401 replacement
4401s come with either a bolt on rear yoke or a slip yoke . I,m not familiar with the ones in the cuvcs . I have some here to compare ,but if memory serves a common NP 241 is a direct replacement and holds up as good if not better despite being rated as lighter duty . If you would like I can do a comparison to insure I'm stating fact . Rick .
rustystud
3,389
Woodinville, Washington
Get a NP205. Then you will never have to worry about it going out again.
