cucv stereos
Midnight Rider
Sesser, IL
I put a over head liner (Highliner) from LMC in my m1008. I really like it. It also has built-in speakers system(it is the same price to buy it with the speakers or without and there pretty good) It is a little pricy (269.95) and made for the truck but I am certain you can make it work on your m1009. LMC Truck Parts: Chevy Chevrolet Blazer S10 GMC Jimmy S15 Ford Bronco Ranger Pickup Pick Up Accessories/Catalogs part number 38-2044-BL or page 111. I need to take pics and show you what it looks like.
I was looking at do my install this way. How does the liner get stuck to the roof though? Glue, screws, ??????
gt1009
st.charles,IL
You can get an underdash mounting kit and put it in there. Then you don't have to cut the dash and you can use the stereo spot for switches or guages or something.
AJMBLAZER
Paducah, KY
It has the 2 knobs. Mounts flush. Would have to cut the plastic, but not the dash.
Got a picture? I'm having a hard time picturing this. There's no way a CD would fit through the metal hole in the dash for the display portion of the stereo on any pre-IFS GM truck I've ever seen.
jw4x4
Dayton, Ohio
The center hole is deifintely an issue. I saw the 2 knob setup and thought it would fit. Upon further review, probably not, at least not without some cutting. My next option will be to mount a unit on the cage. At least that way it stand a better chance of staying dry. I am leaning towards some type of water resistant system.
AJMBLAZER
Paducah, KY
That's what I was thinking. For as much work as it would be you could just cut for and install a DIN head unit and be done with it.
Dizzle
Providence, RI
I busted apart a better set of computer speakers, and used the built in amplifier. Then found an old phone car charger, and snagged the 12 to 6 Volt converter since my PC speakers used 6V. Then soldered it all together with original volume control and on/off switch into a small box that fits in place of the ash tray. The original jack wire that plugged unto the PC is now in the glove compartment and I can plug in any common MP3 player, radio, etc. I mostly use my phone since it's always there and has a radio and huge MP3 storage. The amp was a bit small to be using with 6x9 speakers, they got drowned out at highway speeds, I installed the original speaker portions of PC speakers into the dash under the vented parts, and they work fine for me. Not impressing any pimped out Civics, but a nice stealthy set up thats always there, and I have unlimited choice of audio input.
I know it's really oddball, but can't hurt to share.
Lawrence of Arabia
Howell MI
Radio Options
I just looked in my LMC catalogue and they offer a modern stereo that fits the GM dash. You can go online at LMCTRUCK.COM and look through their catalogue.
AJMBLAZER
Paducah, KY
The problem with the LMC stereos is:
A-They aren't all that great
B-They aren't CD players
C-They're a bit high priced
Better to just cut the dash to make a DIN sized CD player fit.
maritimer
Yarmouth, NS
well i just put a small shelf stereo between the front seats and plugged it in to my inverter and hook my mp3 player to it. but i been toying with the idead fo pc speakers instead of the shelf stereo to save space
AJMBLAZER
Paducah, KY
You know...just putting this out there...but for all the ingenuity and work you guys have put into these center mounted stereos and PC speakers and inverters and blah blah blah...it's not terribly hard to put a DIN CD player in the stock location and speakers in the dash and where ever else you want to do it. Basic tools, a metal saw, and a drill along with the components. Do some bargain shopping and you can get the stuff quite cheap. I actually got good components for mine and with a CD player and two sets of speakers I still don't have $250 into mine.
dunedigger
Hart, MI
I have 6 of the older gm trucks and have put cd players in all of them right in the dash. I always make two cuts on each side of the stock opening and fold the metal back out of the way but not completly cut it. That way if I ever wanted a post radio back in I can bend it back and tack it back in place. I want to add a radio to my m1009 soon and will put speakers in the dash and that will be good enough for me.
