RE: Re: RE: Cummins WMO mix
Hmmm, didn't compage filtering WMO between the two systems as I was not doing it at the time, but in checking up on things beforehand, I found that some folks in my area using spin on filters went through one every 15 gallons with the WVO that they had (and of course, this gets a bit dependant on your source of waste oil and how you treat it before you fine filter it...), but a buddy was able to run the same oil through a sock filter and go for 400 gallons at a shot...
One of my coworkers is using a surplus military fuel fiter housing that he has converted to bags, it is likley the least expensive, large filter setup I have seen personally...
One thing that I like about my setup is that I can process a lot of oil on a Saturday afternoon...
It's easy to see what is going on, and things are real flexible...
Scratching your head and asking (as you are doing) and thinking about what your are doing now and may be doing in the future is the best you can do. In any case, no matter what way you go, you can usually swap around, upgrade, trade, or sell pieces and parts if they don't work out "right" for you.
