- 3,752
- 1,534
- 113
- North Carolina - FINALLY !
Thanks, after getting the fiberglass topper off (that's where we found the rust) we; I have a buddy that also likes doing these types of repairsIts already too late but you really don't want to cut it off at the pillars.... WAY unsafe. Your best bet was to drill all the spot welds off the top panel and remove it. Porta power the inner structure up to where it needs to be (the shop that did the estimate should be able to print off the measurements for you.... if not I should be able too). Since you already made the cut you need to to separate the pieces. We haven't replaced a roof on this model yet so I don't know how many inner sleeves are in the pillar.... if there is more then one you need to remove more sheet metal and make extensions pieces. You don't want all your seams in one spot. Preferably they should be about 6 inches, at the minimum, apart. It actually creates a weak point if all in one spot. Ill attach a crappy pic I drew up real fast that hopefully explains what I'm talking about. If you have any questions feel free to ask or feel free to ignore me also haha. Best of luck!
