I WILL LOOK ON OTHER SIDE TOMORROW THANKSI believe there are many tires that were purpose built for theatre and did not need a DOT code. I noticed that 2 of my tires did not have one on the outside wall but did on the inside, so the DOT code is only on one side of the tire. If you can't find it on either side, perhaps it was never built for DOT specs?
These are the first Goodyear tires ive had and i looked at all 4 on the trailer looking for a serial number . Iooked around the bead and where the the sise is printed and i had read about the 4 digits first 2 the week second 2 the year so i will look again today whats the chances they are all 4 turned to the inside! ThanksThey are only one one side. Last 4 numbers will be separate from the others. I've never seen an MVT without a date code
Dot numbers should always face outwardsThese are the first Goodyear tires ive had and i looked at all 4 on the trailer looking for a serial number . Iooked around the bead and where the the sise is printed and i had read about the 4 digits first 2 the week second 2 the year so i will look again today whats the chances they are all 4 turned to the inside! Thanks
when your looking at a mvt where are you finding it ln conjuntionton to the tire sise or the mvt on the sidewall? Near the the rim of middle of tire ?Dot numbers should always face outwards
Ok great maybe i just missed it will look in just a few Thanks again!It's right above the wheel lip. It will all be in pairs of numbers. It will be under the small print warning label that is dead in the center with the tire size above it if I remember right.
.Love the trailer, wish I could find one of them!
I have wanted one since the first one i saw but i could never seem to find one and when i did they would want 5 or 6 grand which i wasnt going to pay then i stumbled on this the end of last week 150 mi from home for 2 grand i said hell yea tits still on the tires and the top is perfect so saturday i brought it home and pressure washed it and now i have to order more paint !Love the trailer, wish I could find one of them!
Yes young man you are correct i now have a camo 1082 for sale if you need one of those ?.
If I am not mistaken, chucky has a single axle version of that trailer.
That one above is a M1095 Believe the single is a M1082
.Can you still tow that with your overhang?
And while we're at it, you stole that trailer so you should return it.
No at the moment i sold the only trailer i could pull with the truck was my 989a1 but my plan all along was to get a 1082 or 1095 and make a adjustable length telescopic beam tounge on which ever trailer i went with and use big slide pins and box beam heavy wall like a log trailer to slide in itself to colapse it or extend it out to 4 or 5 feet so the box/ top on the trailer wont get into each other like ditch crossings kind of articulation is my plan and just to make more work i think im going to do it to a 1082 and the 1095 both for what ever i need it to do for the trip and sale my other 1082Can you still tow that with your overhang?
