Db2 injector pump electrical connectors
87cr250r
1,966
Rodeo, Ca
Nobody is being helpful and I won't be either. The CUCV models use Packard connectors but the HMMWV does appear different from your picture.
Maxjeep1
1,912
Las Vegas Nevada
I needed same parts long time ago. Part numbers were listed in the TM with a diagram. I don’t know the exact TM but I believe it was 165 pages and for the 6.5 diesel.
Mogman
8,903
Papalote, TX
I do not see anything wrong with the picture you posted..
If you are talking about the boots they should have been replaced by the rebuilder if they were bad, they likely would not be "regular" Packard boots but you may be able to cut regular boots down to fit.
Just be very careful when removing the terminals that you do not twist the leads going into the housing, there is a nut under the boot that should prevent that from happening but do not let whatever is left of the boot from twisting.
