Dead battery meets rubber hammer
rivired
federal way washington
lol that's great idea..ive never tried but am gonna right now..i think just for any half-tards..
"BE SURE TO WEAR EYE PROTECTION WHILE BEATING BATTERIES WITH LARGE MALLET"
kaiser2help
East Freetown, MA
And I thought I was the only guy who drops the batteries to loosen the sulfation. Just remember, as previously noted, the batteries are not built like they once were. And dont drink while you are doing it. L.O.L:roll:
tie6044
51
Blaine, MN
I've also heard to put the charger on "jump" mode a few short times and that is supposed to do the same thing as the hammer trick but I've never had any luck with that, maybe the betteries were too far gone. I'm gonna try the hammer method next time.
Mbsk01
TX
If I drew a line between the terminals, the sides parallel to that line I called front and back.
Perpendicular to that line, I called the sides.
Bob H
167
This is the Deuce section, so I was referring to the 6TL's Which have posts in opposite corners, so a line between posts would be diagonal
Look inside the filler cap. The plates run left and right to the sides.
Bad eyesight I guess, I can't really see in there, maybe if I drained the acid down some.
Right now I'm guessing the sides are where the grab handles are.
