Deuce fuel adjustment
cbvet
20
Northwest (Knox) Indiana
I keep reading where guys are getting 10-12 MPG in multifuel Deuces. The best I've ever hit was about 8 with desplined front hubs & traveling at 45 MPH.
I'd like to try turning the fuel down, but need some help.
How can I tell the "best" setting for this engine (non-turbo) ?
Can I damage anything by turning it down too much?
How can I tell if I've turned it down too much?
Suggestions appreciated.
Eric
CBVET
gimpyrobb
dumpsterlandingfromorbit!
27,791
788
Cincy Ohio
Have you tried a new air filter, correct tire pressure, and Checking the valves are set right? Is your truck a powerhouse? If your FDC is in use, it has a screw with 2 nuts on it(must be a boy screw) Anyway, loosen the one closest to the radiator and screw the 2nd one out(so that the screw is able to go further into the housing. You have to make sure that the screw itself does not turn or you could break the spring connected to it on the inside of the FDC. I really think this is a poor option. I would look to put a turbo on first.
cbvet
20
It's got a new air filter, tires are at 50. I haven't adjusted the valves.
Last valves I adjusted were on a '63 Studebaker Hawk, but I'm sure I can handle it.
Truck starts instantly & runs really strong.
Would a turbo really improve mileage?
Thanks,
Eric
CBVET
gimpyrobb
27,791
788
Cincy Ohio
Well, if you have black smoke, that is unburnt fuel. Usually that results from too rich a fuel mixture, which a turbo would correct. Most of the turbo deuces I've driven get about 10-13mpg. I guess a cheaper way to correct the "over fueling" would be to turn down the screw, but where is the fun in that? :)
kaiser2help
East Freetown, MA
Lets not loose sight in what these machines were designed for. These motors, especially the LDS,LDT, orLD's Spent many years in Olivers, Fergusons, and many other old farm tractors. Smoking while you are accelerating hard is okay.However, once you have levelled off you should be burning clean. Just heat currents coming from the stack. My 5 ton only goes 45mph. But I will pull 2 DEUCES at once maintaing that speed. Torque monsters when properly maintained and adjusted.I will tell while towing a deuce I will not get 8 to 12 miles to the gallon. More like 2 to 4. COMPROMISE is never ending. Naturally aspirated motors are great runners too. Even better. If the multi- fuels were so good they wouldnt need a turbo to clean up their emissions. I love em anyways.
m-35tom
226
eldersburg maryland
non turbo should make little black smoke when just running at 45 mph, however when pulling it will make quite a bit. adding a turbo will improve fuel milage and clean up the exhaust but with the fuel turned up for max power it will still really smoke when working
Djfreema
Santa Clarita, Ca
I turbo charged my old VW jetta diesel and went from getting 43 mpg to 47mpg without any fuel adjustment to the injector pump. Not directly related to a duece but shows how turbos will increase the fuel milage.
