Deuce locking fuel cap
73m819
329
gainesville, ga.
In VN, a lot of our trucks had tank cap locks, kept the little rat bast-ards from droping a garnade wraped in a rubber band in, the rubber band let go in a bit , bang
73m819
329
gainesville, ga.
Uh....
Which idea are you complimenting with that post???
The one about brazing the tank with fuel inside
OR
The one about dropping a GRENADE in the fuel filler?????
Just wunnerin'
:shock:
Thay would lift the cap, pull up the filter, drop in the grenade, after a while the rubber band rotted, bang
willy
Martinez, CA 94553
Lock
Yes simple idea and you could weld the nut on the bolt this woudl make it difficult to remove.
But I like your disclaimer take off the strap it does not look like you did the bolt on the strap is not removed any way it does not look like it.
Willy:)
joshs1ofakindxj
119
SW PA
I was thinking about drilling a hole in one of the tabs on the fuel tank cap, then padlocking a chain to it which would be bolted directly to the frame behind the fuel tank. The chain would be tight so that once the lock was on the cap couldn't be turned.
