Deuce Mileage?
dc3coyote
19
Chattanooga TN
I know this has been brought up before. Heck I read it last week.
There was never an answer theough so I will ask.
What kind of millage does a multifuel get with the different fuels.
Oh yea I read for an hour and a half before I broke down and asked.
Branan
Sarge
Austin, Texas
RE: Deuce Millage?
I keep records.
Over the past 11,692 miles, my deuce has averaged 7.6 mpg on straight diesel.
Was that any help?
-Sarge
m-35tom
222
eldersburg maryland
RE: Deuce Millage?
should get 10 mpg on diesel, any less probably indicates dirty injectors. at $3.50 / gal i would fix them
ygmir
northern CA
RE: Deuce Millage?
I get 10-12 on diesel, easy running, empty. Less depending on load, hills, terrain..........
I'd say any other fuel will be lower, probably related to the difference in BTU's/gal, as a percentage...........
m-35tom
222
eldersburg maryland
RE: Re: RE: Deuce Millage?
cbvet, 10 is normal so i would say yours is a good candidate for injectors that are not spraying a mist as they should. i would think you would see more black smoke than most people also. timing could be an important issue also and is very easy to check.
cbvet
20
Northwest (Knox) Indiana
Tom,
Non turbo. Does that make a difference in mileage?
Starts great, runs great. It definitely smokes, but I don't have another to compare it to.
I use diesel conditioner regularly. It's supposed to keep the injectors clean, but who knows?
I'll see if I can find timing instructions in the manual.
Thanks,
Eric
FormerNewMVGuy
10
stockton NJ
Yeah the 70 psi in the fronts is great! I average 10 MPH on the highway with my deuce, and that is mix of clear diesel and the red offroad stuff, about 50%.
1,178
Rebelpride said:
I thought I'd read in a TM somewhere that you can put 70psi in the tires. So instead of 50 i can guage them to 70 and be fine, not ill effects?
All of my original ndcc tires say 65 psi max, so I would consider that and their age/condition.
I have new commercial tires on the front of mine and they are at about 100 psi(talk about easy steering)! My rears are at 50 psi.
