Deuce Mud Run Advice Needed
1,810
Rizzo, I refer to that as a self correcting error. Once you have a thumb jambed or worse, you won''t let it happen again. I also have a problem with the left elbow vs left door.
disco
Houston, Tx
Is it practical or feasible to add a steering damper? I would imagine the shock would have to be pretty hefty to have any effect.
FSBruva
Marietta, GA
m38--
Your axle boots are leaking... what are they leaking? Grease isn't a lube that "leaks" - it usually "oozes" ... unless it has some help from some 90w GO.... While you've got it apart, buy the inner axle seals (and perhaps bearings for both sides) and perhaps some wheel cylinder rebuilt kits. Don't ask me how I know.
Matt
CanonNinja
Houston, Tx
disco said:
Here's my stuck picture. The ground looks deceivingly firm. To complicate matters, it rained a few times after I got it stuck. Of course the axle boot on that side is torn. My seal kit came in last Friday.
This of course is good justification for a winch and bigger tires! But the new seals and paint is next.
Post up pics from the mud run!
Holy moly!
Oh wow, another Spring area MVer... cool!
disco
Houston, Tx
My poor neglected truck. It's gonna be a while before I can actually drive it. My work schedule isn't very cooperative. Being on the bottom of the seniority list isn't conducive to getting your chores and projects done.
