ccequipment
- 7
- 18
- Unionville,IN
I put one through its paces off road for a weekend in a mudhole that was draging the axels hard with 46" tires, never had any damage to it. If you spring an air leak there is a valve that will shut the air off to the air assist when the presure drops below 75lbs or so, letting you still have good brakes, until you can stop and shut off the manual valve, shuting the system down and you will have the normal unassisted steering.
