Deuce questions
eeyore357
B'Ham AL
Thanks. I made a puller that should work as good or better than the original one. Hopefully the rain will hold off tomorrow so I can try to get the pesky thing off. I will post pics of the puller tomorrow, weather permitting.
eeyore357
B'Ham AL
Got the old steering wheel off and column rethreaded and new steering wheel on. Replaced a few reflectors. Got new wood on the bows and finally got my cargo cover on. I have been painting and just general clean-up. I ordered a set of new wheel cylinders and after closer inspection I believe it's the axle seals. I should have a new set of axle seals and boots, remote master cylinder, and shocks in today. I am going to go ahead and replace everything so I don't have to worry about it for a long time. While I'm doing the axle seals I am going to replace all of the axle, trans, and transfer vents and run a tube up to the dash.
thj327
millbrook,al
Have fun. The axle seals aren't bad to do. I used a transmission jack to out the drum assembly on/off. Think it will be done for the this weekend
eeyore357
B'Ham AL
The palet jack was a big help! My friend is letting me use his garage to work on it and he's closed on the weekends. I hope I have it done before the Brierfield show.
