islandguydon
- 787
- 113
- Michigan
I have a pto generator I want to attach to the rear pto, I need an adapter for hook up, does anyone know who might be able to help out..?
DOES NOT drive the REAR wrecker WINCHyou can get a rear facing PTO Accessory Drive that mounts on the rear of the pto to run dump trucks hydrolics or 4,500 pound rear winches on wreckers. but it only turns one way (no reverse). however it would take a very long drive shaft to reach the back. i thought about mounting a pto generator from northern tool under the box on my M109a3 but it is not water proof and the may be a ground clearance issue. i think i am going with a 12 and 24 volt two altenator system with a 12 volt battery system to and inverter so i don't have to run the motor and don't take a chance of running down my starter batteries.
This is driven by the XCASE pto, as on the 815,sorry, thats what i was told here on steelsoldiers when i thought about putting in a pto generator. i was told it ran the hydrolics for the dump bed or the winch that sits right behind the cab with a chain or belt. so that is what i repeated.
dump hyd.cool, glad to know that. then what does the one that mounts to the back of the pto run??
