- 10,883
- 814
- 113
- Appomattox, VA
Hope someone responds to this soon, plan to leave for Gilbert PA in about 4 hours and hope this is nothing major...
I changed the oil in the deuce today, checked all the systems to prep for the trip to PA. Filled the radiator all the way to the top. Then I took a 40-minutes ride around town doing errands. On the way there and back, when the deuce was being taxed, going up hills and going 55mph down the road, there were some splashes of coolant coming out the driver's side engine access panel, enough to splash a half-gallon or so of coolant down the left side of the truck. Had to hose it off at home.
Here's the thing I can't figure out: no leaks in the radiator. No visible leaks in any of the hoses. ONLY did it when the deuce was being heavily burdened by my gas pedal foot. Could not replicate this when I parked the deuce and pulled out the throttle for a few minutes. When the engine was shut off and cooled down, I checked the oil, no water or foam or anything like that, just perfect. Removed the radiator cap, coolant was still pretty high, close to where I filled it to, and the top of the radiator was relatively cool.
Also, something I noticed, is it supposed to be pretty hot in a deuce cab, with no heater, when it is operating?
