Deuce tow rating
593
12
Ville Platte, LA
Not sure exactly how low I need to go, but 14-16 inches should be more than adequate. I feel certain the jack should raise the trailer at least that high.
Might have to put out a request for frame rails for anyone junking or bobbing nearby.
LC
LC,
Guys in my local MV club are cutting up a deuce frame (from a scrapped truck - you could use the cut off piece from a bobber) in two foot sections to weld/bolt below the frame on deuces that they want to tow trailers with. Then they will mount the hitch and it will wind up only about 14-16 inches off the ground. With a two inch drop bar that would only be a foot off the pavement for the bottom of the ball - how low do you want to go?
