bottleworks
- 3
- 18
- Central NC
Did you at least get your money back?dm22630 said:I went....paid my $10 to get in...then was told that I could NOT pull because I had dual tandem axles!
..doghead said:First picture,starting line. Second picture, the grandstands are off to the right! Yes, Full Pull.
From the tractor show I went to this summer, they reason they extend the chain is so the angle of the chain is equal for for all tractors/trucks regardless of hitch height. most of the tractors have very low hitch points, while the one guy with an m37 had a higher hitch point. they extended his chain, and if they hadn't he would have been doing a wheel stand much quicker.I pulled in 1st gear high range and had no trouble. They extended the chain to make it harder for me to pull.
