rustystud
- 3,389
- 113
- Woodinville, Washington
Your right, my bad !There is no "turbo" pressure regulator. The housing on the left side of the block has a relief valve that opens at 40 psi (dumping excess pressure back into the pan) and a valve that opens at 15 psi minimum for the piston cooling nozzles. The turbo is fed off of the same system as the engine bearings, etc.
I just got back from Hawaii when I posted that so my mind was still adrift ! I need to medicate myself when flying as I get really sick due to inner ear damage. I wonder if that turbo supply hose is internally damaged causing a restriction ? I know it comes off the main pressure galley so there should be good oil pressure there.
